- 1 feb 2004
A new Enigma1 PLi? Dreambox release is available for download.
The Original Enigma1 PLi? Jade Final suite contains the following images:
* PLi?-Jade-DM500
* PLi?-Jade-DM500-MaxVar
* PLi?-Jade-DM500-Old-Framebuffer
* PLi?-Jade-DM500-MaxVar-Old-Framebuffer
[Old-Framebuffer: only needed if you have a greenish OSD when using the normal DM500 software, if in doubt use the standard DM500 software]
* PLi?-Jade-DM500Plus
* PLi?-Jade-DM56x0
* PLi?-Jade-DM600
* PLi?-Jade-DM7000
* PLi?-Jade-DM7020
Download hier
See below for what's new & fixed since the initial PLi? Jade RC release
Highlights:
- Satellite.xml split in Ka, Ku, C, S, L band
- Remote control behaviour reverted to pre-Jade
* (Some remotes suffered from very bad reception in the Jade RC)
- North America scan fix by Updatelee
- CDK Flashtool: support flashing between standard partition layout and 'MaxVar' partition layout!
* ('Var' partition is erased when the layout changes)
- Rotor improvement for the OpenEmbedded (OE) boxes
Enigma1:
- CVS Repository June 29th 2008
- PLi? Repository September 29th 2008
- Enigma Movieplayer fixed by ims
- Default sleeptimer now 30 minutes
- Insert and delete character support for DM500 remotes (Red and Green)
* Now Red (delete) en Green (insert) can be used.
* For all other boxes Vol+/Vol- and Red/Green can be used - it does not care...
- Remote control behaviour restored to pre-Jade
- Fixed 'DM7000 style' remote control for DM500
* (Added the ability to use the DM600, 7000, 7020 large remote on your DM500, DM56x0)
- Show serviceselector again with TV/RADIO key, but only if the mode already was TV resp. RADIO.
* Toggling TV/RADIO doesn't bring up the service selector
- Timeshift delay input value limited to 999 instead of 60 seconds
- Timeshift / recording support for DM500+ (settings equal to DM600)
* (Smooth start and faster rotating at 18 V, motor stop detection improved)
Plugins:
- Bitrate plugin fixes for NTSC
PPanel:
- Channelsetting reload in PPanel fixed
EPG Features:
- Use audio key for searchEPG in EPG channel
OSD Features:
- OSD transparancy setting in smaller steps for DM500+ and DM600 (5 instead of 25)
Web Interface Fixes:
- Some info in WebIf missing for IE fixed by ims
Network:
- Enable network and DHCP as default in case the Enigma config is not copied from /Var_init
* May fix some move /Var to network issues
- Do NOT add manually created mounts to the Enigma mount.conf
* It can cause double mounts if such a mount was already done in /Var/etc/init
Highlights DM500 MaxVar:
We've created 1Mb extra /Var space for you...
The removed items are now available via the PLi? downloads at the Software Management
We rebuilt the internal Flash tool completely!
So now you can flash back and forward between the standard PLi DM500 images and the PLi DM500-MaxVar images without using the serial cable!!!
We advise you to use the 'root.cramfs' method for this!
See the url below on how to Flash your DM500 via the 'root.cramfs' method:
See our DM500 Installation Wiki...
Moved to Software Management downloads:
- MV EPG plugin, Mediapli_8 skin, CCcam SoftCam, Cables/Terrestrial.xml, Translations, Games, traceroute, nslookup, IPtables, Netfilter drivers
Further:
- Thanks to Updatelee for North America scan fix
Thanks to the PLi testers for several fixes and features
Support:
- Online update support (IPKG feed) for OpenEmbedded boxes
* (DM500Plus/DM600/DM7020)
- Global satellites.xml updated September 29th 2008
* (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal; DVB-S2 can't handle auto-FEC)
- Satellites.xml split in Ka, Ku, C, S, L band
See our PLi? Wiki...
Further, our Pli member Jonc created a Wikipedia Tool and PDA WYSIWYG Desktop Application for the PLi Dreambox images
If this DM500 version proves all OK, he will put the other Wikipedia Tools and PDA WebIf version online for the DM56x0, DM500+, DM600, DM7000, DM7020 and the limited E2 wiki.
Many low level changes fixes and other updates...
* PLi?-Jade-DM500
* PLi?-Jade-DM56x0
* PLi?-Jade-DM600
* PLi?-Jade-DM7000
* PLi?-Jade-DM7020
Download hier
Highlights:
Enigma1:
Plugins:
PPanel:
EPG Features:
OSD Features:
Network:
Further:
Support:
