- 8 feb 2001
- State Penitentiary
Steeds meer in opkomst is het programma Twitch. Een programma waarmee je met games mee kunt kijken bij andere spelers.
Hieronder staat de handleiding om dit als app werkend te krijgen op een Samsung Smart Tv. Deze handleiding is in het Engels maar op verzoek wil ik hem wel vertalen indien nodig.
NO GUARANTEES
Software is provided as is but as far as I understand it works on majority of modern models.
Project on Github
Installation (Repeat to update)
Make sure your TV is connected to the internet.
On your TV, go to Menu->Smart Features->Samsung Account and type name "develop".
Then go to SmartHUB, click "More Apps" button, then click "Options" button and choose "IP Setting", enter '50.17.189.245' and finally choose "Start App Sync" option. TwitchTV app has to be installed now.
For 2014 models "More apps" button might be absent, if so try: long press the enter button on any app, then the menu will pop up, select IP Settings, put in the IP, then long press enter again and then Start User Apps Sync.
For models released before 2013 you might want to use these instructions instead: From the SmartHUB main screen, click the "Tools" button on the remote. Only from the "Tools" menu, navigate to "Settings", and from there to "Development". (You still have to be logged in as 'develop')
If you are getting Render Error
Render error is popped when TV software doesn't support format@resolution (quality) you are trying to play.
Source quality is different on each stream so your tv might support it on a stream and giving error with another one. There is nothing I can do about it.
Low, Mid, High are same on every stream so if one of them is working/not working for you on a stream it will/will not work on any other.
TLR If you are getting render error try playing around with the quality.
How to change quality
Open panel - left or (when panel is closed) center buttons
Switch quality options - (when panel is open) channel up & down buttons, or 1 & 4 buttons
Confirm quality change - (when panel is open) center button
Hide panel - right or back buttons. (if you press back when panel is hidden player will close)
NO GUARANTEES
Project on Github
