Arabians, Hungarians and Czechs Font Fix
Auto-Channel Search with empty Settings hangup fixed
16:9-Scart-voltage must be permanent 6V when 16:9 is selected and "16:9/4:3 Auto-Switch" is off
suppress any messages from external CAM when +CAM is working
AC-3 Auto-appointment with fall-back to MPEG-Stream (only D0-Ident)
ORF-DD-FIX
General DD fix for stream recognition fro some AV-Receivers
Symbolize +CAM Activity
Ident-Table included
Switch-Optimizing and Bugfixes
AU-Fallback for 06xx 17xx
TPS-Fix
CAM-Reset on 0-RCL
Macros for ON/OFF key allowed
Macro Mode Control Key with TV/SAT,EXIT or some other key
Display CI Window disable/enable
Scrollable list of CaID/ECM/Ident
AVP = Auto Video Pid disable/enable
ToH Menu to control all functions
Parser for CAT and PMT
Tic Tac Toc
Advanced Timebugfix
