wiltop@msn.com;200829 zei:
Bij dbox nokia , kon ik de opstart bv volgen , wil dat ook graag tbv opstart newcs met cccam , daar mijn cardlink maar niet wil connecten met newcs
hoop dat ik he duidelijk omschrijf
BV DIT SOORT INFORMATIE
CS mit Newcs & CCcam
hi leute
hierbei bleibt die server box dunkel
wenn ich newcs starte kommt das:
logger config: level 1 type 3 output 5
Console log options: level 1 type 3
TCP log options: level 1 type 3
[ 00:30:27 ] [ Box detect ] Box type 4 (Dbox2)
[ 00:30:27 ] [ httpd ] httpd-user: newcs, password: newcs, accesslevel: admin
[ 00:30:27 ] [ EMM Cache ] Initialising dynamic Cache
[ 00:30:27 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 278
[ 00:30:27 ] [ Loader ] Starting Telnet on port 1001
[ 00:30:27 ] [ Loader ] Started HTTP-server on port: 8080
[ 00:30:27 ] [ Loader ] Reader type 4 on node /dev/tts/1
[ 00:30:27 ] [ Dbox ] Opening device /dev/tts/1
failed to open/dev/rtscts: No such file or directory
rtscts device: Invalid argument
rtscts device: Bad file descriptor
[ 00:30:28 ] [ Loader ] Reset failed ...
[ 00:30:28 ] [ Loader ] Starting Newcamd Server on port 10003
[ 00:30:28 ] [ NewCS ] Ready to GO!
/var # [ 00:30:29 ] [ Newcamd ] Newcamd thread Server started on port 10003
starte ich dan die cccam mit CCcam -dv:
/var # CCcam -dv
00:32:22.899 CCcam: ======================================================================
00:32:22.906 CCcam: starting CCcam 2.0.9 compiled on May 17 2008@15:55:36
00:32:22.908 CCcam: ======================================================================
00:32:22.919 CCcam: online using nodeId b34c118a2cef61a2
00:32:23.090 CCcam: dvb api3 detected
00:32:23.096 CCcam: create 1 cam device(s)
00:32:23.113 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
00:32:23.115 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
00:32:23.117 CCcam: static cw not found or bad
00:32:23.119 CCcam: parsed 0 entries from /var/etc/CCcam.prio
00:32:23.123 CCcam: readProviderfile: cannot open /var/etc/CCcam.providers or not found
00:32:23.125 CCcam: readChannelList: cannot open /var/etc/CCcam.channelinfo or not found
00:32:23.127 CCcam: server started on port 12000
00:32:23.209 CCcam: newcamd server 127.0.0.1:10003 user: Charly
00:32:23.276 CCcam: newcamd first read failed -1
00:32:23.278 CCcam: newcamd receive error -1
00:32:33.357 CCcam: newcamd server 127.0.0.1:10003 user: Charly
00:32:33.395 CCcam: found betacrypt caid: 0x1702 ecmpid: 0x1742 id: 0x0
00:32:33.397 CCcam: found betacrypt caid: 0x1722 ecmpid: 0x1c43 id: 0x0
00:32:33.398 CCcam: found nagra caid: 0x1837 ecmpid: 0x1a42 id: 0x0
00:32:33.399 CCcam: found nagra caid: 0x1833 ecmpid: 0x1842 id: 0x0
00:32:33.401 CCcam: found nagra caid: 0x1834 ecmpid: 0x1c42 id: 0x0
00:32:33.402 CCcam: found nagra caid: 0x1836 ecmpid: 0x1843 id: 0x0
00:32:33.403 CCcam: found nds caid: 0x9c4 ecmpid: 0x1b42 id: 0x0
