B
Bennieboy
Wist niet waar ik het moest plaatsen dus dan maar hier.
Ik krijg het niet voor elkaar om newcs me smargo smartreader te laten herkennen. heb van alles geprobeerd.
Deze melding krijg ik steeds.
Bboy:/home/ben/newcs# [ 21:44:20 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 21:44:21 ] [ Loader ] Reset failed ...
[ 21:44:21 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 21:44:21 ] [ CardMan ] Reseting reader parameters
[ 21:44:21 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 21:44:21 ] [ Phoenix ] Setting Parity to: ODD
[ 21:44:21 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 21:44:21 ] [ Phoenix ] Setting Baud to custom 16129
k[ 21:44:22 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
illal[ 21:44:23 ] [ Loader ] Reset failed ...
[ 21:44:23 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 21:44:23 ] [ CardMan ] Reseting reader parameters
[ 21:44:23 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 21:44:23 ] [ Phoenix ] Setting Parity to: ODD
[ 21:44:23 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 21:44:23 ] [ Phoenix ] Setting Baud to custom 16129
l n[ 21:44:24 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
ew[ 21:44:24 ] [ Chameleon2 ] Failed to lookup remote
[ 21:44:24 ] [ Chameleon2 ] Failed to connect to remote on port 1234 [Next try in 11 seconds]
c[ 21:44:25 ] [ Loader ] Reset failed ...
s[ 21:44:25 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 21:44:25 ] [ CardMan ] Reseting reader parameters
[ 21:44:25 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 21:44:25 ] [ Phoenix ] Setting Parity to: ODD
[ 21:44:25 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 21:44:25 ] [ Phoenix ] Setting Baud to custom 16129
.[ 21:44:26 ] [ Newcamd ] new connection from 192.168.0.51 on socket 11
[ 21:44:26 ] [ Newcamd:34001 ] Connection from 192.168.0.51
[ 21:44:26 ] [ Newcamd:34001 ] User ben logged in, client: CCcam
[ 21:44:26 ] [ Newcamd:34001 ] Connection from ben to not-ready server!
[ 21:44:26 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
Weet iemand hier wat ik fout doe?
Groeten,
Ben.
Groeten,
Ben.
