Inmiddels kun je de ( nieuwe ) firmware downloaden.
Alhoewel die daar staat heb ik tot nu toe niet iets nieuws in kunnen ondekken. Wel wat hij van plan is de komende tijd.
Citaat:
I've seen that many new users subscribed to this site; now is time to work, this is a list of to do things over here
* Tuner:
I'm working on it now, my intention is to create a menu tha does an automatic transponder scan, and that creates a channel list with provider names on top; I am thinking as well to start working on a new concept user channel list.
* OSD:
OSD means On Screen Display, and as you know it displays a channel list, the menu, different infos, etc.. As it is for now surely let's you figure how old our receiver is. My intention is to create anuser upgradable "skin system" with a better look. This is not easy because nokia's CL9100 has only 3 display modes: lo-res, med-res and hi-res... the first two defines a single pixel to 2x2 with 16 colours, the hi-res mode defines a "real" pixel 1x1 but it only uses 4 colours.
* Hardisk
This receiver as you know can use a SCSI harddisk, so why don't we do something for this?
Firstly we need to convert filesystem from FAT16 to FAT32, so we can use bigger partition than the FAT16 2GB. After this we can surely use Harddisk as a memory expansion, for examlpe for storing channel lists, plugins, mp3, mpeg1 videos and why not.. make it possible to use it as an mpeg2 reader and recorder?
* Common Interface
The Nokias 9600 communication between cam and receiver is very poor an weak, so it's not suitable for recent cams. That's beacuse we need to fix it, and so we need betatesters for this.
Bron: DVB2000.GOT.TO
