Humax IRCI5400 Allcam Patch v2.0
  • Topic starter Topic starter theGIZMO
  • Startdatum Startdatum
Status
T
theGIZMO
Een nieuwe patch van het Humfree-team is gereleased...ditmaal wordt de embedded Irdeto-CAM een All-CAM ! HIC 1.01.10ph V2.0 is de eerste versie die daadwerkelijk autoswithing ondersteund. Voor meer informatie/theorie achter het autoswitchen zie de bijgesloten Readme.txt.
Oeps, onderaan de pagina van planet hemp stond toch de link, is een beta versie ...
CU
Red
En hier de vertaling van de readme :
(Met L&H software, dus vol fouten, maar beter dan niks)
== == == == HIC10110-+CAM -.HDF - version +CAM PH 2.0 == == == =
The V2.0, the first version participates, that a real Autoswitch
between different CA-IDs realized.
In contrast to the previous definition of " Autoswitch "
go the V1.7 far over this until now possible out:
On the basis of a solid eingespeicherten list of the most frequent
CA_IDs - 0602 1702 1722 and 1762 - supplements through the CA-IDs
this itself on the used card decides - seeks these
Firmware actively in the sent PM-Tabellen after one
Agreement. The Haupt-ID of the card is preferred with it
treat. Only when is found no agreement
can, comes the automatic case-mess table the carries. This
take care of it that also with lacking agreement
at least the Haupt-ID this in the PM-Tabelle was found
one appraises.
This completely new technology participates this from the SE-CI-CAM until now
used " Probiermethode " far thinks!
Through this technology, it possibly participates also cards without problems
, to use deviant CA-signals from the standard as well, for example
0605 or 0603. Until now also not yet used signals
will work without an Update of the firmware.
Since some Provider several signals for the same program
uses, some peculiarities nevertheless must heed
becomes: The defaulted rich-consequence of the to be used
CA-ID participates like follows:
1.) The main-signal of the used card
2.) 1702
3.) the sequence of this of ID within the sent PM -
Table.
Through this fixed sequence almost always participates
guaranteed, that EACH card co EACH signal EACH CA-ID
can process.
On the basis of some example shall the is clarified:
Card-signal 1762 - reception of a supplier with the signal
0602
In the PM-Tabelle, no agreement can with the 1762
is found, therefore function is entitled to the case-forecastle the carries.
Also the signal 1702 doesn't occur in the PM-Tabelle, therefore
another case-forecastle to the first signal within the PM -
Table. The card becomes consequently with the EMM/ECM Streamses of this
Signal 0602 looks after...
Card-signal 0602 - reception of a supplier with the signal
1702
In the PM-Tabelle, no agreement can with the 0602
One uses the 1702 and the card becomes with these EMM/ECMS
Streams looked after...
The absolute special cases - from the standard deviant CA-IDs -
become possible through this procedure first.
The only restriction exists with cards of Providern
this several CA-IDs within an encoding-system
uses. A card with the signal for example 1702 can under
becomes no circumstances on another signal of eingeloggt,
as long as these cards CA-ID in the sent PM-Tabelle
existing participates. As concrete example, ATV participates from the PW
Package quoted. Come in the PMT belonging to this canal
both 1702 as well as 1762 as signals before, so that always
the signal of the card uses becomes. At canals this only this
1762 as signal in the PM-Tabelle carry, ORF, can however
easily on the 1762 as signal is switched. Also
all other signals put with this Kartentyp no
Problem there, as long as the card-signal in the sent PM -
Table doesn't occur.
Friend problems:
Through the partially inert construction of the PM-Tabelle causes can
occurs that when switching between different
Providern with different CA-signals no one
usable data in the PM-Tabelle can be found.
Through renewed switching within the wished
Providerpaketes can this holding back in most however
Cases is remedied.
Avoiding Tunlichst essentially participates participate canals this no one.
The popular copyright-notes in the downloadbaren Settings
belongs to these " canals ". In most cases participates after it
no PMT evaluation more possible, so that only a complete
Latest-type of the Receivers remains.
Through the extensive Multitasking of the firmware and him/it
scarce Ramspeicher conditional stands it and at to a type
Hänger come, that however usually itself after some seconds
solve.
In very rare, not comprehensible cases, can it to
locks a complete the firmware comes, that only
through a hard Reset, appliance of the network separates, solved
can become.
Since only singularly the card-data with the start up of the appliance
completely from the Standby is read, should with one
Card-changes a latest-manner is executed. Becomes only so
guaranteed, that the new card-data for a possible
Autoupdate current participates.
Even if this clearly widened in the function-scope
Firmware the impression should awaken that the HumFree team
from his/its line " support only of Originalabos "
deviate, that doesn't participate the case! This firmware only pulls
on a tie as well from other side available
Hardware-solutions. Still becomes no definitely
Support for pirate-cards or emulators achieved!
Remain closed fun with the new firmware " only one " much
wishes.
Planet Hemp & HumFree team
@ The Gizmo
Deze vette Smile betekent dat het werkt!?
Grtz Mike
@Mike The Bike,
Zeker weten...ik hoef niet meer uit m'n luie stoel te komen voor het betere zapwerk.
Bij mij werkt 't dus duidelijk niet met de 401 versie, de 501-versie kan dit , volgens Wimpie, ook niet! What's the difference?
versie 401 (I.V.S.) + 16f628 en 24c65
Grtz Mike
Het werkt met alle mosc kaarten ik hoef de kaarten niet meer te wisselen.
Zo blijft er meer tijd om mijn heerlijke biertje te drinken :)
snik :-( weer iets leuks in die hic 10 . en dat is juist net de soft versie waar ik . en mede stab interface gebruikers problemen mee hebben... jammer moet ik toch elke keer weer uit die luie stoel komen :-)
gr dj
En ik maar wachten pffffpffffpfffpfff op mijn kaartjes die ik besteld heb om van al dat moois te kunnen genieten :sad: :( :sad: :( :sad: :( :sad:
exDumber
En ik met mijnen Goldprogger kan die nieuwe chips niet proggen. Ik zal mijnen Aston dus nog niet moeten wegdoen ... ;-)
CU
Red
Ben hier ook even aan het stoeien geweest met de allcam patch en moet zeggen werk redelijk goed op een originele asc 1.2 c+ kaart beeld op ned - premiere - atv -bd zenders zonder de kaart eruit te halen (de rest zal ook wel werken maar nog niet getest).
Maar soms verslikt de softwarte zich dan geeft hij geen beeld met de aston had dit op de france zenders en op de nederlandse (had er toen geen irdeto kaart in).
Maar door even goed door te zappen springde hij weer aan.
(hij zag dus de kaart in de aston niet)
Al met al knap stukje werk en zullen de mensen die premiere niet op de humax aan de praaat kregen nu minder problemen ondervinden om dat het niet meer uit maakt wat voor type kaart je gebruikt.
Ik heb deze versie er ook even ingezet, maar die is NIET autoswitch voor het DS9 project.
Trouwens....zit vol spellingsfouten.
Service is scramled or not runing ?
moet zijn
SCRAMBLED en RUNNING !!!
Stefaan
HMMMM heb je wel de zelfde versie, hier zegt ie dan
bv : 0602 - This service want your money.
Ja hoor ik heb dezelfde versie wnat hier zegt ie dat ook soms...en het moet ook zijn "wantS your money"...met een S.....zit vol taalfouten die versie!!!
@Stefaand
Waarom beweer jij dat dit niet werkt met het DS9 project en theGIZMO wel?
Ik kan alleen de 501 versie niet proberen, maar de 401 versie loopt bij mij definitief niet! -> autoswitch niet, manual switch wel!
Grtz Mike
@Mike The Bike,
Even een correctie mbt DS9 na een dag hobbyen...regelmatig switch ie niet of het duurt meer dan een minuut ?! De hardwarematige reset oplossing, mbv de afstandsbediening, blijft toch een geschiktere oplossing.
@Stefaand,
Even aan de slag met een hex-editor om de taalfouten te verbeteren is niet zoveel werk.
Manual switch werkt wel goed...maar ik dacht dat ik gelezen had dat die autoswitch was....helaas...
bedankt voor jullie reaktie.
Stefaan
Status
Naar boven Naar onder
