MANUAL Skystar2 en ProgDVB
T
Tuurtje
Op verzoek zet ik hem weer even neer.
Is in het Engels door mij gemaakt omdat ik voor de Skystar normaal op een buitenlands forum zit.
======= MANAUL TUURTJE 07-12-2004 =======
This is the way i have done a lot of installations that did NOT worked before.
Never failed me (but if you have suggestions to this manual, please do so)
If you allready have installed the Skystar 2 do the following:
1 - In hardware properties (Device List) Disable the Skystar card and reboot
2 - Unistall dvbviewer and Technisat DVB software
3 - Manually Remove all files with the name: SKy*.dll from c:\windows\system32
4 - manually delete file SkyNET.sys in C:\WINDOWS\system32\drivers\
5 - check all files in C:\WINDOWS\inf\oem0.inf with notepad (LOOK FOR ALL NAMES: oem0.inf oem1.inf oem2.inf etc to find the SkyNET file.
in my case it was oem15.inf
============-== text in inf file ==================
SkyNET.INF - WinXP, Win2000, Win98 and WinME com ......
Delete oem15.inf and oem15.PNF (OR THE ONE YOU FOUND)
IF YOU DON'T DELETE IT, IT WILL TAKE THE WRONG INF FILE FOR INSTALL
Now that your system is clean, download latest driver from Technisat:
http://www.technisat-daun.de/download/en/soft/1018.zip
1 - extract it to C:\TS430\
2 - delete in C:\TS430\DVBViewer the setup.exe (is stripped down version of DVBviewer you won't need it)
3 - Check in the hardware properties (Device List) that the Technisat DVB card is NOT listed anymore, otherwise delete it yourself.
4 - reboot computer and when it starts it will say new hardware found.
point to the folder C:\TS430\ (this only will install the driver)
5 - reboot again and go to folder C:\TS430\Install and run Setup.exe (this will install registry settings and autostart for card) IGNORE error that something could not be installed
When all went well the card is now up and running after restart.
1 - install latest ProgDVB h**p://www.progdvb.com/download.htm
during installation UNCHECK both filters so that they won't be installed also pick from the list Sky Star 2 and leave the directory as is: C:\ProgDVB\
In next property screen leave timeshift at disabled
In next property screen you can disable Stream Router if you do not want to stream pictures accross a network.
Uncheck Run ProgDVB after install SO DO NOT START THE APPLICATION YET
2 - Delete all files and folders in C:\ProgDVB\Transponders\
download from Joshy h**p://joshyfun.peque.org/transponders/index.html only the transponders that you need and put them back in C:\ProgDVB\Transponders\ ( in my case: 0130.ini 0192.ini 0282.ini )
3 - find file: S2emu1.09.zip and extract all files to C:\ProgDVB\
4 - find file: Softcam.key and allso put it in C:\ProgDVB\
MPEG Codec:
Install Elecard MPEG codecs or Cyberlink (YOU NEED THEM BEFORE STARTING ProgDVB)
Now start ProgDVB.exe and go to menu [Settings] - [DiSEqC] and take the correct one
(in my case i have a 3way DiSEqC switch connected to a Visio Bisat Dish So i will take DiSEqC 1.0 or 2.0 Check the firts entry Not connected and Add LNB to Astra 1B (check next entry and add LNB to Hotbird) (and the third entry to Astra 2A)
Go to [Channel List] - [Channel search] and scan the transponders one by one
Thats all
Tuurtje
Ik heb een probleem met progdvb.
En dat is het volgende als ik op de thor wil kijken dan lijkt het wel
of ik heel slecht signaal heb,Want dan is het beeld niet goed.
Maar het signaal is prima,En andere programa`s Zoals alt-dvb en dreamtv hebben daar geen last van.
Heb jij mischien een oplossing Tuurtje.
Groetjes Jackie
Jackie kan je niet helpen, ik heb geen Thor dus ik kan niks voor je testen.
Groeten Tuurtje
Tuurtje
Bedankt voor de respons.
Groetjes en een fijne feestdagen toegewenst,
Jackie
