satellite eu
Er is 'n nieuwe versie van CamX verschenen; versie 1.09.
Dit is 'n gedeelte uit de change-log:
This is still a beta version for test.
Supports dutch c+ smartcard ecm/emm & sharing
**only in lower slot**
Emu does ecm on i/s/s2/v/n/t/c
Emu does emm on i/n
**requires /var/keys/SoftCam.Key**
**requires /var/keys/AutoRoll.Key**
**requires /var/keys/Conax.Key**
Config files included
**must be in same dir as camx and server /var/bin**
**or on i386 in same dir as server-i386**
- 1.09
* Removed s2-emu support for the time being
* Camx now NG, server+client in 1 no more loose files
* Removed SC support from camx, moved all SC to server thread
* Fixed bugs in network EMM
Linkje:
http://65.75.149.180/~satellit/inde...6&func=fileinfo&parent=category&filecatid=164
Emu does emm on i/n
- 1.09
Linkje:
