Menu - 1 t/m 9 is het orginele DVB 2000 menu . dit is op div. adressen te downloaden in het engels of duits .
De First Dutch Satellite Club Europe heeft een ingebonden nederlandstalige uitvoering .
Van de Sandra menu's heb ik ook geen beschrijving .
Bij mijn NoOneManIt 1.2 download zat ook een readme file , Hier het gedeelte betreffende het menu :
0 - PMT ECM PID Scan
If the selection in automatic rifle of the PID of the ECM had turned out wrong, you can use this menu; you obtain the directory of all the systems of codifies itself contained in the PMT with relative PID ECM and, in case of codifies SECA, also the relative IDENT. Selecting one activate that one like PID of the ECM.
1 - 1x CAM ResetInit
2 - 2x CAM ResetInit
3 - 3x CAM ResetInit
1 or 2 or 3 reset of the CAM with successive INIT of the same one will be carried out. Particularly useful for use it of the decoder with some known types of smart-card
CA system ID
It comes visualized the type of codifies current marked from the smart-card during the last one reset.
4 - ECM PID
If also with function 0 the intentional result were not obtained, you can use this function for manually set the just PID of the ECM.
5 - Last PMT
Is be repeated here for commodity the possibility to visualize the last received PMT of the channel in vision.
6 - Autoswitch
Is possible to set up from the order of preference in I use here of the several codifies, independently from how much envoy from the smart-card at the moment of its insertion. As an example, if we activate V-I-S (that it means 1° Viaccess, 2° Irdeto and 3° SECA), going on a channel first firmware look if in the PMT exists a PID ECM for the Viaccess, and if this finds the CAM use it. If it in the second place does not find the Viaccess try with the Irdeto. If finally also thus the search fails, then try with the SECA. The first PID of the ECM that will be found following this order, will be that one used from the CAM.
7 -SECA reorder
Is useful for those provider SECA that they use to send in the PMT more relative PID to various IDENT, of which some quite they are bogus. With this option activated, the program, before choosing the PID of the ECM, will carry out reorders of those SECA in such way to put to the first places those just ones, and to move instead in bottom those bogus.
8 -CAM
The type of CAM must be set up that we have. Obviously if decoder is 9200/9500 will be possible one not to set up nothing of various from " Embedded ", while for the 9600 you must to be set up the type of present CAM Common Interface. Is particularly important as an example to choose that just one in the cases of Aston 1.03 (for the visualization of Stream) and FreeCam.
9 -View SECA PBM
If in the present PMT is one or more SECA codifies, you can view for each the date, codified and decodified, and the PBM.
A -Next Menu'
From it is passed to the successive menu here that at the moment is nearly all disabilied. ; -) I have suspended the realization of the visualization of the EPG of D+ because they have begun to send the EPG also as the Dvb standard.
Gr. Trust
