Specification:
Wafer smartcard
OS version 1.02
Flash: 32 kB (28kB free)
RAM: 1024 Byte
Eeprom: 32 kB
Crypto: Yes (RSA)
Protocol: T0 / T1 / TE
Language: ASM, (C)
Programmable @ 3.57 MHz using Smart Mouse
SmartKey Titanium Features:
General
High-performance, Low-Power Secure AVR RISC Archtiecture
133 powerfull Instructions ( Most executed in a single clock cycle )
Linear adressing of up to 8 M Bytes of and up to 16 M Bytes of Data
Low-Power idle and Power-down modes
ISO 7816-2 compliant
ESD Protection to ~ 6000V
Operating range from 2,7 V to 5,5 V
Compliant with GSM, 3GPP and EMV
Memory
ISO 7816 Controller
Up to 625 kbs at 5 MHz
Compliant with T = 0 and T = 1 Protocols
Two I/O Ports (Configurable to Support Communication Protocols including 2-wire Interfaces)
Serial Peripheral Interface (SPI) Controller
Programmable Internal Oscillator (Up to 16 MHz on ROM)
Two 16bit timers
Randum number generator
2-level, 8-vector Interrupt controller
Hardware DES and Triple-DES DPA Resistant
Checksum Accelerator
8-bit GF (2n) Multiplier
Crypto-coprocessor (Pre-programmed Functions for Cryptography and Authentification, including RSA, DSA, Key Generation, ECC) Security
Dedicated Hardware for Protection against SPA/DPA Attacks
Advanced Protection against Physical Attack, Including Active Shield
Environmental Protection Systens
Voltage Monitor
Frequency Monitor
Temperature Monitor
