Two updates of firmware to activate keys guide and pilot in SRT8000 H or I with instr
  • Topic starter Topic starter Kees Bl
  • Startdatum Startdatum
Heeft iemand dit al geprobeerd? Ik heb wel de file gedownload, maar het veelbelovende commentaar hierboven wekt bij mij toch enige terughoudendheid op.
heeft iemand deze files al getest en is dit ook de fix voor het even uitvallen van tequilla en kiosque
Depending on the version of firmware that we have installed in our sera receiver necessary to load one or another update. To the day of today (20-4-01) version OEM 38 (DA5IB.BIN) Italian is the one that better behaves as far as visionado of ticket offices with black screen (pantallazos) random. If we have DA5IB.bin installed in our receiver we will have to update with the file epgdeadcafe1_1ita.bin. In the case that we have it completes Dutch version OEM 20 (DA3NEDE3.BIN) without black screen random but without visionado of ticket offices we will have to update with the file epgdeadcafe1_1ned.bin.
To connect the cables series and parallel segun indicates STRONGSAT. To form mediabox to loader for the corresponding COM and to load (file/load) bin adapted to ours firmware (Italian or holandes). Maintaining keys MENU and > of the frontal to ignite the receiver of key ON/OFF until it appears CHA in display. In mediabox to loader aparecera something similar to this: Depending on the version of firmware that we have installed in our sera receiver necessary to load one or another update. To the day of today (20-4-01) version OEM 38 (DA5IB.BIN) Italian is the one that better behaves as far as visionado of ticket offices with black screen (pantallazos) random. If we have DA5IB.bin installed in our receiver we will have to update with the file epgdeadcafe1_1ita.bin. In the case that we have it completes Dutch version OEM 20 (DA3NEDE3.BIN) without black screen random but without visionado of ticket offices we will have to update with the file epgdeadcafe1_1ned.bin.
The checksum not they can coincide but not you give them importance. Once finished the process to put out and to light the receptor. All the interactive functions of CSD were available in your SRT8000H/I. As it can be verified has not been necessary sintonizar canals since have incorporated them in the firmware. That user that want personalizar their canals by means of eliminacion, change or adicion to should do it now. This actualizacion carries incorporated 111 canals of CSD and 499 from Other to date of today.
73 cordial Dead Cafe Team forever.
Het werkt. De spaanse c+ kanalen hebben epg en ook de interactieve kanalen zoals formula 1 en liga de futbal doen het. Ook Meteo blijkt interactief. Je kunt mbv de serv toets bijv de weerkaart van europa oproepen. Tot zover het positieve. Je zenderlijst wordt vervangen door een CSD lijst en de nederlandse kanalen zijn weg. Na het opnieuw inlezen van de kanalen blijkt de CSD epg nog te werken maar helaas bij onze eigen anal+ geen epg meer. Blijft over de tequilla kanalen, nee dus. Wat mij betreft geen blijvertje.
Hallo,
Do you have the 10 seconds error in your strong8000h whenn updating to epgdeadcafe1_1ned.bin.
Do you updated from versie 15 or 20.
And what for operator do you work with because I have heard when you update the strong with windows millenium your reciever crashes and with windows98 and windows nt not.
thanks for your answer.
and 73 cordial Dead Cafe Team do you have a url....
Wallie
Ik heb WinME en heb geen problemen ondervonden. Verder zit versie 20 er in en dat moet ook zoals je in de vertaling van NvBgm kunt lezen. kiosque kan ik je nog geen antwoord op geven maar wat wel belangrijk is is dat het "steek de smartcard enz" melding verleden tijd is. :-)
smartcard insteken heb ik geen last van en waarom kun je niks zeggen van kiosque. Dit werkt toch ook gewoon...
Weet trouwens ook iemand wanneer mijn reciever update naar firmware20
Goed, ik heb het ondertussen ook getest en ja, het werkt wel grappig, Ned. menu met Spaanse epg en info en spelletjes e.d.
Hun epg en info stelt tenminste wat voor
Echt veel heb je er niet aan verder op dit moment maar ik ben wel zeer nieuwschierig naar de volgende versie
Wie weet hoeveel epg`s dan kunnen werken
De Taq`s werken hier alleen met software versie 15
Bij de 20 is het beeld mooi zwart (ach ja, mooi zwart is niet lelijk)
Maar mischien als je de 255 credits op je mosc hebt toe gevoegd dat je dan wel beeld hebt
Het zou kunnen, ik krijg die er om de een of andere reden niet op.
Grtz. Kees.
Naar boven Naar onder
