hier het gedeelte van de INI file met de wijzigingen en instellingen voor mijn systeem freecam 2.020 Nokia 9800S
# defaultmode: 0=Eurocrypt, 1=Viaccess, 2=Conax, 3=Seca, 4=Irdeto, 5=Videoguard
defaultmode=4
# defaultconaxmode: 0=beta 1702, 2=beta 1722, 6=beta 1762, n=nagra, c=conax, v=viaccess, i=irdeto, s=seca
defaultconaxmode=c
ShowExtraEcmDetails=off
# if set to 'on', send all response data at once (faster, shorter delay),
# else send byte-at-a-time (slower but more compatible)
# Default is off (a Force don't like it being on)
#CamHighSpeedMode=off
# 30W mecm debug..
# default on = PC will beep (about 5 seconds in advance) when an error in mecm data is detected
# so you can watch out for it's result
#BeepOnNagraMecmErrors=off
# default debug modes (hex)
# initial value on start, and up to 4 values that can be toggled
# debug = initial deb1 deb2 deb3 deb4
debug = 01 01 03 07 ff
# default serial port debug modes
# syntax as for debug
serdebug = 01 01 03 07 ff
# Directories for data files [datadir] and log files [logdir] :
# Use "" for current working directory
#datadir = ""
#logdir = ""
# automatic checking for add_*.dat:
# N: =0 never, >0 check for add_*.dat files each N seconds
#autocheck = 120 ; each two minutes
autocheck = 0
# automatic saving og key files *.dat :
# N: =0 never, >0 save key files each N seconds
#autosave= 14400 ; once every 4 hours
autosave=0
# SA hunt settings:
#sahuntinc = 0x100
#sahunttimer=180
# For the system sections [xxxx] :
# port=N
# for port= 1 => COM1 2 => COM2 etc.
# baud = NNNNN
# direct or inverse : use direct og inverse byte convention
# parity = mark/space/even/odd/none : usually "direct=>even" and "inverse=>odd"
# Often used values for baud are 8860, 9600 and 10472
# optional user defined ATR :
# atr = N1 N2 N3 N4 N5 N6 .....
# Log file names for log file and key updates:
# mainlog= "my.log"
# updlog = "my_update.log"
En dan heb ik de baud bij Irdeto ingesteld op 8861
Met deze instellingen loopt mijn systeem als een trein
