#xbins op efnet
daar tik je /msg xbins !list
en dan krijg je dit :
FTP ADDRESS: distribution.????.org
PORT: 21
USERNAME: uw nickname op irc
PASSWORD: emulation
log in met een ftp client en ga naar
/XBOX/apps/dashboards/evolution-x/_official
daar staat'ie, vlijf wel op de irc server anders gooien ze je af de ftp
maar beter is de slayer cd af te halen, das een cd of dvd die alles voor jou installeerd met handige menu's
zal ff copy/pasten uit de nfo file :
>>>>>>>>> This installer was originally created by SlaYer! <<<<<<<<<<<<
Feel free to modify, but please leave this credit file in place.
To get the latest Version of the Installer follow these instructions:
* IRC Software: Get your free MIRC Client from here:
http://www.mirc.co.uk/get.html and choose the link closest to you.
* IRC Server = snoop.burghcom.com ( IRC Server Join Command = /server snoop.burghcom.com )
* IRC Channel = #SlaYerS ( IRC Channel Join Command = /join #SlaYerS )
The channel BOT, called "Bitch" will automatically send you what you need if you issue these simple commands:
!help - tells you how to configure mirc to allow you to get files from this channel! - DO this FIRST!!!!
!nfo - sends you both NFO files (open with Wordpad to read properly!)
!installer - sends you the installer in one 60MB file
!ip - info on fixing IP problems
!modchip - modchip info
!xbmp - bonus! get the latest Xbox Media Player
For Q&A Support see the Xbox-Scene Forums here:
http://forums.xbox-scene.com/index.php?act=ST&f=16&t=23507&
